41 - 50 of 50 Posts
Discussion Starter #41
1994 Firebird Formula
K&N CAI
CRT Intake Elbow
Cat Delete
New speakers in doors - one 10' in back
Trans Am hatch
Tinted tails/corners
C5 Rims F17x8.5 R18x9.5
I figure I'm at 300 at the flywheel? Expecting full exhaust soon. Longtubes, y-pipe and pipes out the back.
it should be more than 300. if i remember they were rated at 275 from factory, yet i think everyone knows they're underrated. i'm thinking like 320-340
My 2006 dodge charger. WAY too much to list haha. My first post by the way
Welcome to the 4. Hope you enjoy it here.
Very nice! Really clean work, I like the '10 wheels on there.
1989' LX Mustang
~ HATCHBACK (CHARCOAL GREY) GARAGE KEPT
~ NEW CARPET
~ 302 BORED OVER .030
~ BALANCED & BLUEPRINTED BY STATKUS ENGINES
~ COAST HIGH PERFORMANCE 347 STROKER KIT (FORGED RODS & PISTONS)
~ BLOCK IS O-RINGED – FOR HIGH BOOST
~ SCAT STEEL CRANK W/ GIRDLE
~ ALL ARP STUDS
~ CLEVITE 77 BEARINGS
~ SCORPION ROLLER ROCKERS 1.6 RATIO
~ MILLINGS OIL PUMP
~ SPEC STAGE III CLUTCH
~ AFR 185 HEADS 2.02 INTAKE / 1.60 EXHAUST
~ GT-40 INTAKE
~ BBK 70MM THROTTLE BODY
~ FORD F-CAM 512
~ PRO M 77 MASS AIR METER
~ POWERMASTER 140 AMP ALTERNATOR
~ MSD 6-BTM WITH BOOST RETARD
~ WAHLBRO 255 IN TANK
~ T-REX IN LINE FUEL PUMP (80LB/HR)
~ 42LB INJECTORS
~ MSD IGNITION WIRES
~ TREMEC 5 SPD (HEAVY DUTY Z-SPEC)
~ PRO 5.0 SHIFTER
~ VORTECH S-TRIM W/ POWERPIPE
~ SN95 ELECTRIC FAN
~ BBK HEADERS & H PIPE
~ FLOW MASTER DELTA 40S 2 CHAMBER
~ EXTERNAL PHANTOM FUEL PRESSURE GAUGE
~ INTERNAL BOOST PRESSURE & H20 GAUGE MOUNTED ON PILLAR
~ PHANTOM TACHOMETER W/ SHIFT LIGHT
~ STEEDA ADJ. QUADRANT
~ 3.27 GEARS CURRENTLY ON CAR
~ EIBACH LOWERING SPRINGS IN FRONT
~ CODE ALARM
~ FULL INTERIOR
~ A/C POWER
~ POWER STEERING
~ MAXIMUM MOTORSPORTS - 6PT ROLL CAGE WITH SWING OUT ARMS
~ 5 POINT SEAT BELT HARNASSES
~ PRO3i UPPER/LOWER CONTROL ARMS
~WELDED SUBFRAME CONNECTORS
~WELDED DRIVE SHAFT SAFETY LOOP (LAKEWOOD)
~ WELD DRAGLITES
~ 15 X 3 FRONT
~ 15 X 10 REAR.
~ 275/50 15 BFG DRAG RADIALS
Recent Dyno #'s reflect: 548hp SAE & 590fl/lb torque.
BQM: 11.80 @ 122.X mph
http://i111.photobucket.com/albums/n156/digdeep0169/Mustang for Sale/avatarmustangpic2.jpg
1989' LX Mustang
~ NEW CARPET
~ ALL ARP STUDS
~ MILLINGS OIL PUMP
~ GT-40 INTAKE
~ FORD F-CAM 512
~ 42LB INJECTORS
~ PRO 5.0 SHIFTER
~ SN95 ELECTRIC FAN
~ CODE ALARM
~ FULL INTERIOR
~ A/C POWER
~ POWER STEERING
~ WELD DRAGLITES
~ 15 X 3 FRONT
~ 15 X 10 REAR.
I miss both of my FOX body mustangs big time
I like how you roll man!!!!
87 Buick - 3" downpipe, TA54 turbo w/ported elbow, 2-3/4" exhaust, ported upper plenum, 42# injectors (450-500 hp depending on how much boost)
Just read this again. I love those cars. GN or Turbo Buick? Or GNX, in which case, I envy you.
2011 cts-v with a smart car engine swap, gas is going up :/
1993 Nissan 240sx hatch (I sold her 2 years ago)
SR20DET Motor and tranny swap
GReddy 24 row FMI
Apexi type 2 BOV
Apexi 2mm head gasket
Apexi Fuel pump
Pioneer 6" head unit w/ navigation
GReddy 4" downpipe
Apexi 4" exhaust
Apexi test pipe
16" unknown wheels
Apexi N1 suspension coilovers
HID headlights
Apexi stage1 single plate clutch
Car was dynoed at 247 rwhp
Stainless Works 1-3/4 Headers w/HFCats
Stainless Works 3in Exhaust
8.5 MSD wires/coolsoxs
160 t-stat
Katech Short throw
Lingfelter CAI
Torques HyperBlack>245/275
SpecWerkes bushings
TKS Rear Strut Tower Bar
smoked sidemarkers & fogs with 55w-8k-HID
PCV catch
Aeroforce-column pod
CS Grey Motor Mounts
350whp
Damn Shady, you're rollin w/ some serious cars right there ;). When are you going to be back in NJ my man? Hit me up!
41 - 50 of 50 Posts
