What carpet extractors are you guys using?
1.4K views 9 replies 6 participants last post by  Envious Eric
#1 ·
Well I've been thinking about picking up an extractor for my shop and this morning on my way in I dumped by Starbucks through a turn :(. Guess its time to buy.
What do you guys recommend?
#7 ·
A heated carpet extractor is a necessity if you're a detailing professional, you should have a hot water extractor for the efficient and labour saving cleaning of carpets and upholstery.
Hot water extractors outperform wet/dry vacuums many times over. A vacuum can miss sand and sticky or oily contaminants that adhere to fibre. When hot water and detergent is added to the process, this debris is loosened and sucked into the extractor.
An extraction system process is the choice of professional detailers due to its cost effectiveness, performance efficiency and time saving over conventional methods. Extractors work by using a cleaning solution dispensed from a tank that heats the solution to 200.oF+ and is sprayed at medium pressure, high volume from the machine via a cleaning wand; it is then filtered and re-circulated. Extraction also allows the ability to remove cleaning residues due to its high suction power (100-inch water gauge +). Rinsed fabrics look and smell cleaner and resist soiling better.
The Sensei Extractor sports sizable 6 gallon tanks, but is only 28 inches high (with handle down). A neat, fold-over handle makes it easy to transport and store. So easy, you can carry it in the trunk of a car, which makes it a perfect choice for mobile detail units. Top of the Line (TOTL)
#8 ·
Once I figure out where I'm moving at the end of next month I'll be purchasing an extrator. I used one quite a bit at the high volume shop when I was 16 and now almost 10 years later I miss it. A wet vac does a decent job but I definitely agree that an extractor is a necessity and ends up being cost saving by hours.
