Bad day for Vboxing.. First, I tried to run the car like 5 or 6 times, and each time except for 1, the damn vbox shut off.. The power cable broke when I sent it out to use at the Miami Mile. I got this new top heavy universal cable and the slightest movement in the cigarette lighter shuts it off.. I dont know if it would still record the run until shut off?
2nd off it was very windy tossing the car all around... Same road I tested the Lp560 on, dead flat, approx 65 degrees..
This run was done on reg mode which boosts 15psi on pump gas..
0-60= 3.3 ( lots of wheelspin) (3.5 stock)
0-100= 7.7 ( full second faster than when i was stock)
1/4 11.5 @ 122.8 (stock mph was 117.8)
Im certain I could better this under better circumstances.. Lowering the tire presure would help alot as its set at 50psi in the rear and 43 upfront.. Next Ill try it on sport mode, which bumps boost to 17psi on pump gas...
