1 - 9 of 9 Posts
So, for some reason, my tire pressure monitor tells me I have 0 pressure, but when I come to a stop to check the tires, the pressure goes back to normal. Could the sensors just be dirty? Also, the RR and RL are showing up for the opposite sides. When my tire deflated on the driver side rear, the sensor showed rear left.
You should be able to find how to reprogram the sensors in your manual. Try that.
If that doesnt work - maybe the sensor has gone bad. You havent filled it up with air from a gas station or used fix a flat on it - right?
Maybe even the battery is going on it.
1 - 9 of 9 Posts
