21 - 33 of 33 Posts
a 210 is not a plane for someone who has 0 hours. Yes, I know, you've probably heard of a guy who's uncle knew someone who flew it to get his license, but it's not. My cousin started flying his father's when he had about 80 hours, but that's a different story, he had been around airplanes since he had diapers, etc. A 210 is NOT what you want, believe me; too much power, too much speed, too heavy, etc. You'll get behind it too quick and it'll bite, and hard.
Airplanes are not like cars, you have to start very basic and move your way up. In that sense they're more like motorcycles, you have to give them infinite amounts of respect.
Get a 172 to start out, forget range and speed. Speed, usually, comes as a compromise to slow speed handling, and that's not a tradeoff you want right now. Cirrus', for example, fly fast yet their wing isn't approved for spins, that's why they have a chute. A chute sounds like a cool idea, yet do you know when the most probably time is to enter a spin? Just before landing (turning base to final) when you're 500' above ground, and the chute is useless at that altitude, you're toast.
A 182 is more reasonable, but still not what I'd get. One bad landing on a 182 and you'll bend the firewall (nose gear does not attach to the engine mount like a 172). And in cruise you'll pick up 20kt over a 172 and some useful load, but not what you want right now, for the aforementioned reasons.
Forget the trinidad, there's a guy at my field who's been trying to sell his for years to no avail. A 172 is by far the best bet; cheap to acquire and easy to sell, after all it's the most popular light airplane in the world (most units sold). Everyone and their grandmothers know how to fly and fix a 172.
Then, once you gain hours, and experience, you can think about moving up to an A36, etc.
A 177 will barely carry two pilots and fuel. Same for a 172. Both are very slow. A 182 will carry the load but it's still slow. If you intend to fly it yourself, get a Bonanza A36. With air conditioning. Six seats, 165 kts., easy to fly. Buy it now and do all of your training, through instruments, in it. You should be able to pick up an early '80s with a mid-time engine and at least one Garmin 430 for less than $150k.
I've had four and I've sold every one for more than I paid.
the bonanza A36 looks like it may fit the bill.
It's an excellent plane. My Brother has a 35 and does a lot of flying in it. He's had it for about 15 years, and I think would be hard pressed to get rid of it because he loves it so much.
Not a machine you want to learn in, but a very good plane to settle down in for a bit. IIRC, you'll need a high-perf. certificate for it, but that's easy with a few hours experience.
the A36 is beautiful, but man, it's NOT a plane to learn in. Lots of people have done it, that doesn't mean it should be done. There was an Arab prince who learnt to fly in a 747. That still doesn't make it right, does it? Follow the normal progression, start in a 152/172 then move up. There's a reason why so many pilots have learnt in them.
Single engine turbine especially in the mountains. The pressurization and the single turbine would make for a safe, fast, comfortable, economical transport. And by the way the best airplane to learn to fly in is something with a tailwheel. That is how I learned and it is like batting with a donut or learning to drive stick first. Once you move on to something with standard tri gear it is cake.
Banned
What airport in the Seattle area ??
As far as Bonanzas go, I'd stick to the straight tail ones. I really liked the v-tail ones until I flew one. It was fast for the amount of power it had, but it felt like it was crawling along on its elbows once we got into a bit of rough air. I have no idea how the guy in the back seat held his lunch because it was dutch rolls for quite a while.
Based on the requirements that you list, you will need something a bit bigger than a 182 for 4 adult passengers and 2 dogs.
I second the idea of a fractional ownership in a larger/faster plane, but you will need to have a certain number of hours before an insurance company will touch you in a complex aircraft. Uaually it is around 150 hours for retractable gear and c/s prop. Beyond that, I will have to defer to others who have more seat time than I do as far as getting into the bigger planes.
Good luck.
I could not agree more with just about everything said here. Although the 172 now has the nosegear attached to the firewall as well. They changed it in the early 2000's (atleast on the skyhawk). The old adage there are Old pilots and Bold pilots but no Old Bold pilots rings true for how powerfull/complex of an airplane you think you can handle out of the gate as well. Start on a 172 then move up to a complex then twin (should you so desire). You will make better progress that way than you would starting on a faster plane. Treat flying with respect because it can and has killed before (believe me I know). But its a love thats hard to beat.
Insurance co.'s not only look at T.T. but also time in type! For example, you could build 500 Hours in a C-172 or something equivalent and even move into a BE-76(twin) for another hundred hr's or so and still the insurance company will want you to go to SimCom(Good/Smart move by the way!!) and then get 100-150 hours in what ever you buy(C421B) before you can get an insurance rate that isn't completely ridiculous($13,000/yr). And you will be required to go through recurrent training each year through SimCom/Flightsafety(or equivalent).. In my case, I was able to network and find a pilot/CFII with 800hr's in the C421B, to fly with me and be the primary on the insurance until I have enough hours to give the insurance company a warm/fuzzy... Having a CFI with you for the first 100 hours when taking a significant step up is PRICELESS!!!
21 - 33 of 33 Posts
