CAD Designed & CNC Executed
T304 Stainless Steel
Double Skinned Casing
Laser Cut Mounting Flanges
Laser Cut Mounting Brackets
Tig Welded Assembly
Mirror Polished Finish
Precision Engineered For Accurate Fit
Improved Low Level Tone
Amplified Mid-Range Note
Increased High Pitch Acoustics
Sharper, Crisper, Sound Across The Rev Range
Volume Increases With Revs
Practical For Regular Use
+ Noticeable Bhp Gain Typically
+ Low/Mid-Range Torque
Sharper Throttle Response
Vastly Freer Flowing than OE
Wireless remote control kits in 3 functions (On, Off, Throttle Pedal Sensor/Engine RPM Auto), in auto mode, the valves will automatically closed at low rpm for better launch start and comfortable driving, when car owners are driving at mid-high rpm, the valves will automatically open for better performance and sound enjoyments, car owners can set whatever the timing for valves to automatically open and close by engine rpm and how deep they press the gas pedal, it’s a new innovation system to bring your car to a whole nother level and it’s not just an exhaust system you’re getting, it’s a new driving experience that you never had before.
NOTE: Armytrix wireless valvetronic wiring is a plug-and-play system, no cutting, alteration or damage will be done to the factory settings.
Complete product information: www.armytrix.com/Porsche-981-Boxster.php
Tig Welded Assembly
