1 - 16 of 16 Posts
Yes we have an overload of Range Rover's at the shop right now, all either modifying or fixing body work. Here is a 2005 Range Rover HSE that we are converting to a 2011 style. This includes the front headlights, front grill (we are painting the surrounds body color), front bumper (we are painting the lower textured black trim to smooth body color), all the parts necessary for the front (we have to do custom work to the fender to make the new lights fit), side grills (painting the outer trim body color) and rear lights (smoking them). To do the pre 2006 conversion to 2010+ is much more difficult then a 2006+. To start we have all the parts now and have done all the wiring up front to get the 2011 headlights to work with zero problems!
To complete the "conversion" you need to remove the big plastic strip on the 'C' pillar! Otherwise, top notch job!
Hi,
No you can not simply take the C pillars and call it a day.
In 2006 (March / April 2005 for the 06 MY) they actually changed the rear windows, they arenow wider and the C pillar trims narrower.
You can change your rears for the post 2006 type window with the thin trim, the trims do come of the old style ones as they can be replaced but if you remove them, the window is unfinished so they have to be replaced..
AlsoI do agree these bits should be left alone to keep the "floating roof" effect.
1 - 16 of 16 Posts
