1 - 4 of 4 Posts
I ordered a V6 Big body range. Was wondering if the wheels and/or tires from my Range rover sport would fit.
i believe the tire size is 285/30/24
Thank you!
The bolt pattern is the same and the offset should be close enough. Just make sure that whoever mounts them realizes that the '15 RR has a 70mm hub, not a 72.6mm hub. 99.99% of tire/wheel shops and aftermarket companies are not attentive enough, regarding wheel hub rings.
ok thanks for the head up.. So what do i do to correct the HUB?
1 - 4 of 4 Posts
