1 - 8 of 8 Posts
Here are some shots from a private gathering we had on Saturday to show off the work of German tuner Novitec Rosso and their fresh twin Suprcharger install for the 2009 Ferari 430 Scuderia.
Here are the details of the work performed:
NOVITEC RACE Bi-compressor F1 430
including 2 supercharger with modified turbine-blades and separated oil-circuit, modified and enlarged induction tract complete heat-insulated, watercooled intercoolers (twice as big as the ones of the SUPERSPORT) with additional watercoolers, pumps, complete modified induction tract with air filter covering, reinforced v-ripped belts, injectors, air tract duct in underbody as well as modified ECU‘s. Switching of the flaps regulation at the Manettino in the steering wheel
mounting
performance: 527 kW (717 hp) / 8.350 rpm
max. boost-pressure: 0,48 bar
max. torque: 722 Nm / 6.250 rpm
Vmax: 348 km/h (in combination with NOVITEC gear-ratio)
0 – 100 km/h: 3,5 sec
NOVITEC power optimized ECU‘s F1 430
higher performance through new adjusted engine electronic with modified group of curves
as well as higher cutoff speed to 8.800 rpm (thereby higher end-speed). Switching of the flaps
performance: 384kW (522 hp) / 8.600 rpm
Max. torque: 488 Nm / 5.450 rpm
Vmax: + 6 km/h
NOVITEC suspension (KW) derived.
Hydraulic adjustment in combination with suspension springs
including suspension spring set for lowering in combination with the original suspension, a 40mm
hydraulic adjustment at the front axle through a remote control as well as a CAN control unit
(the original damper adjustment is kept) F5 430 04
NOVITEC wheels
set wheels / tyres type NF3
8,5J x 20J with Michelin Pilot CUP 245/30 R20
12,0J x 20J with Michelin Pilot CUP 315/25 R20
Discussion Starter #7
Actually the NOVITEC team sent out one of their installers to tackle this beast. Very professional and fun guy to hang with for a few days.
1 - 8 of 8 Posts
