1 - 20 of 88 Posts
So I guess I'll start my thread... a little late since the car is almost together, but better late, than never :rofl:
So I got an 08 z06 mostly stock, had a vararam intake and a tune
Discussion Starter #2
So I decided to do the calipers in a very close color to the color of the car
Discussion Starter #4
Engine Specs:
- LSX Block
- All-Pro Heads with oversized Titanium intake valves and Nitronic exhaust valves
- FAST Intake Manifold
- Nick Williams 102mm TB
- Callies Magnum Crank
- Callies Ultra XD Rods
- Ross custom piston with low compression (9.5:1 for turbo application)
- Meziere WP
- Katech Oil Pump
- Aviad dry sump baffle
- Comp Lifters
- Custom cam
- Cometic head gaskets
- Cloyes billet timing chain setup
Drivetrain:
- RPM Level 6
- RPM Level 3 Rear Diff
- DSS Carbon prop shaft
- RPS Twin Billet Carbon Clutch w/Flywheel
- 300M Axles
- MGW Short shifter with Box
Discussion Starter #5
Suspension
- PFADT Motor Mounts
- PFADT Trans Mounts
- PFADT Pillow Blocks
- PFADT Heavy Rate Sway Bars
- PFADT Spherical Bearings
- PFADT Coilovers
WOW :)
Discussion Starter #14
thank you guys! i am also very excited about it. i am doing it in stages. first finish the n/a kit and than the turbo kit. my guy is busy until August to do the fab work :(
off to a machine shop
1 - 20 of 88 Posts
