1 - 16 of 16 Posts
Co-Founder
I am remodeling my upstairs back into an office space. I have the old style can recessed lights (see pic below). I want to do low voltage or led.
Any suggestions on economical solutions that would put off a cool light?
Thanks
Lutron is one system to consider...Lutron Electronics, Inc. - Dimmers And Lighting Controls Other control systems and low-voltage replacements are available to replace cans. Larger line voltage transformers should be installed somewhere rather than having built in transformers at each can-light [these are very affordable, nice and work similarly]. However, if numerous cans are replaced in the same room, you can hear a very slight buzzing sound with the built in transformer at each light.
You've got a couple of options. Convert to low voltage/halogen as suggested above OR simply put in a dimmer, and 120V Halogens bulbs. OR hell just put in 120V Halogens.
I know of these- but do not know how bright or how well they work but I am willing to try them since I need some more lighting in the living room. If you are willing to wait about two months would have an answer for you on how well they work.
Nik
Architectural LED Lighting: Industrial, Business, Residental
That would like grea Ray do this run each? I like the low voltage systems save on the electric bill also!
Low voltage doesn't save on the electric bill... Electric bill is based on how many watts you use, not volts. To be honest, I never understood the reason for low voltage.
well, since P=VA: Power (watts) = volts x amps
if your voltage goes down, the usage of power (watts) goes down too. this assumes that the current (amps) stays the same, or decreases with the reduction of voltage.
hopefully your bills will be lower now!!
chad
+2nd Lutron lighting systems. Here is a project in Beverly Hills that I've been working on and the Lutron system allows me to control lighting to my likings. It allows you to custom set dimming modes for atmosphere control (sleeping, party time, away, etc.)
Any other questions, don't hesitate to ask.
Joe
The lighting controls do that, not the lights themselves. You can mix and match the two. I'm looking to get the lights that I linked above and use Crestron lighting control.
CJ
Best Lighting Automation in the World
Smart HDL the new leader brands for Home Automation and life style in the world, offers many solutions under one roof and one brand for Lighting, security, Music, curtain, Air condition control, Infrared control, Audio video, User interface, Power meters, SMS and remote control, Timers and Logic, IO analog and digital.
If you are familiar with such system like Crestron AMX, HAI, Dynalite, clipsal, RCS, Lutron, Lite touch ++, you can see how smart and flexable the new smart HDL brand for smart bus system is.
1 - Lighting control: Din rail, and mountable Dimmers and relays, proudly our Product can work in both 110 V and 220 V, 50 and 60 HZ, its green product operated by 24V DC.
a - Din rail dimmers 2 CH 6 A, 4 CH 3 A, 6 CH 2A
b - Wall Mount dimmers 12 CH 10A , 6 Ch 10 A, 6 CH 20 A
c - Din rail Relay 8 CH 16 A, 4 CH 20 A, 8 Ch 10 A, 4 ch 10 A
d - DALI , and Ballast controller
e - We are the first in stage Lighting and DMX Control for big projects like the last Olympics, or for home small disco lighting with our unique DIY touch screen allowing the client to record his party lighting and music and play it when the party start
2 - Air condition control: we can control all type of AC, in our AC module you can control Single and Multi stage unit, 3 fan speed and VAV 0-10 Volt control, 4-20 mA , with external temp sensor terminal. What we can control regarding AC is:
a - Split AC unit by IR control
b - HVAC Fan compressor Relays
c - VAV 0-10 V, 4-20 mA
d - Lon works
e - Any 3rd party AC system integrated by rs485, or rs232
3 - Curtain and shade control, our shade is bus enabled no need to run electrical wiring fro automation, and we have all type of shade motors blind vertically and horizontally curtain. Our curtain features is:
a - Bus enabled (save wiring and conduits)
b - Can carry up to 120 KG
c - Can be stand alone with its 4 daily timer
d - IR remote to integrate with any system
e - Dry contact for integration to other 3rd party system
f - Free Clutch; work in manual and automatic together in same Time.
4- User interface, let me tell you about our Dynamic page LCD Panel, and you will see how old and useless the system you were using.
Our LCD Panel in 1 panel only can do the following:
a - Consist of more than 15 dynamic pages for all functions
b - Control the Lighting channel on off
c - Dim the lighting channel (keep pressing function).
d - Double click function to go to any mode you like
e - Control scene and can dim the scenes
f - Have built in temperature sensor, with adjustable technology
g - AC page controlling the heating cooling fan speed and desire temperate with Auto Mode
h - Control up to 8 others panel as slave for AC. Can be master slave, or master.
i - Controlling the IR for TV, DVD and others devices
j - Controlling the curtain
k - Arming disarming the security system from your panel
l - Music control, you can see the song name album and Genres, select next track pause, play and change the volume.
m - You can set your clock alarm and medicine alarm that trigger ever couples of hours; we care about your health.
n - It supports all language in the world, English, Spanish, French, German, Arabic, Chinese, Russian, Turkish, Urdu …..
o - It support picture on its page for more friendly use
p - It have time and date showing in your LCD
q - It can be locked by password or locked by other commands.
r - It have IR receiver, controlled remotely.
s - It is 2 way for lighting security, AC, Curtain and music
t - Backlit and LED adjustable and auto backlit on depend on motion sensors
u - Much more from A-Z and still the list not finish all this in 1 small panel in the wall.
Also smart-HDL has other interface like 2-4-6 button Panel, touch screen and much more for interface.
5 - Home Automation, we have our advanced home Automation system. We have our Logic module that have 240 Logic table of AND, OR, Nand and xor, that can link all the logic you need.
1 - At time, sunset sunrise, before after time sunset sunrise. time between …. To..
2 - When scene, sequence , channel on , channel off, curtain on off
3 - When flag on off delay time….
4 - When Temp value range between …. To …..
5 - When date, between dates …. Date
6 - When days Sunday Monday …….
7 - When security OFF, Vacation, Night ++++
8 - Link between tables …
Also we are proudly and uniquely have our 6 IN 1 Sensor installed in ceiling very small and elegant with a lot of function
a - It have Motion Sensor
b - Light intensity sensor
c - IR receiver
d - 360 degree IR Sender
e - 2 dry contact to connect to Door window or smoke detector in the room
f - It have 32 logic table inside it to link all this function
g - It support security
h - It is bus enabled
Our system Logic is in all our products, all of it is smart and co-operate together, the system will never stop hung or respond slow
6 - Security , we have our bus security module that can support the following
a - More than 250 000 security zones
b - Can be divided to 8 different security area
c - Support all type of NO, NC sensors Vacation Away Night, Night with Guest , Day , Fire Panic Temp Alarm
d - Auto Arm and disarm depend on the Arming mode
e - Vacation mode to secure your house by saving your furniture and randomly open lights in your home during your absence
f - Bypass and restore the zones , alarm events history
7 - Others , need more, We have a lot of other products I can list to you some
a - Bus GPRS Module to control your home by SMS and the home inform you if any problem
b - Power Meter to know the consumption of your electricity day by day hour by hour and month by month, and it will send you alert if the consumption is high
c - RS232 485 for integration with 3rd party device, we have our own protocol and can receive and send any ASCII command in any baud rate, we can control HEX also. (NUVO Music system integrated ready with our system)
d - IR control with current sensor
e - Room partioner
f - 4 input sensor for security or Automation
g - IO module for analogue and digital input and output
All this you can finish it installation and programming in very easy and short time (2-3 Days for the project)
For more info, Manuals, Films and others you can visit our website www.smart-hdl.com
For installation and Programming Film you can visit www.youtube.com/sbustraining
1 - 16 of 16 Posts
