Lexus LS 460L in for an extensive paint correction and interior detail.
Majority of the paint issues came from automatic car washes and later a paint chip repair guy who attempted some "buffing" of his own, naturally that only added to the issues.
This writeup contains lots of 50/50 pictures and several videos including one on DA wetsanding.
Prep procedure:
Pressure rinse
Foam
2 bucket wash using strong mix of CG citrus wash
Riccardo clay + ONR lube
Multiple IPA wipedowns to completely strip paint of old glaze
Wheels:
Sonax on wheels
Powerclean on tires/wheel wells
Started with the hood, many rock chips attempted to be fixed on the hood and more damage was left than damage fixed
Closeup of defects under Fenix LED
After M105 + wool pad and Menzerna Powerfinish
Wool compounding
Front fender corrected, door uncorrected
Trunk section was too damaged for high level correction using even a wool pad and M105, no sense in even testing out that combination as I would have yielded no more than maybe 75% correction, the gouges and deep rids would be left all over the trunk. In trying to chase down those very deep defects with a wool pad at high RPM I would most likely remove more clear coat than I would like to in the process.
So I opted to wetsand it instead. The entire trunk was DA sanded using 3000 grit discs
Lots of deep RIDS and gouges, again rock chip repair was attempted here and failed miserably.
Before beginning prep on the trunk I let the paper soak for about 40 minutes in lukewarm water
Two 3000grit discs soaking before using
Proper adapter screwed into backing plate for sanding, then the backing pad was put on
Finally after soaking, disc was centered on. I used 1 disc for the right side, and 1 disc for the left side after which both were thrown away.
Slurry left in the process of sanding, water in a sprayer bottled had a tiny bit of pH car soap for lubricity, some like that some dont, I prefer it. Not a ton of water used in this process so I guess you could classify it as "damp sanding" rather than wet sanding.
Readings taken after also
DA sanding Video
YouTube - Machine Wetsanding by Street Dreams Detail
Results and 50/50s after removing sanding marks with the same black wool pad and M105 combo plus foam compounding with Powerfinish, no finishing polish at this point
Prep procedure:
Pressure rinse
Foam
Wheels:
Sonax on wheels
Wool compounding
DA sanding Video
