Hello,Filter relocation plate installed and fittings installed.
Kean?How do you determine the optimal cutout dimensions where the X pipe halves meet? Eyeball it? I think the size and shape must significantly impact whether you get good velocity and scavenging vs. increased turbulence.
575whp is actually like 730 crank hp and tuning wasn't even close to maxed out.... I have good feelings about this car.isn't 575 rwhp a bit low? How much do you think you will be getting out of it once the tuning is done.
Crank/Flywheel basically the same thing and yes.Are LP560s, 560hp (est) at the crank or flywheel?
Sorry about the dumb question, I meant at the flywheel or at the tires.Crank/Flywheel basically the same thing and yes.
