1 - 20 of 22 Posts
Klipsch Quintet Home Theater Speaker System
Price is $225 shipped | CONUS.
I bought a set of these speakers new on sale at Best Buy. I came back to the store a few weeks later and found a second set of the speakers "open box" and for an even deeper discount.
I bought the second set thinking I could set them up in a bedroom or pass them on to someone for a who would enjoy them. I am very pleased with the set in my home. They are being powered by a Pioneer vsx-1122-k and sound great.
Retail is $500-$600.
I took these stats out from an eBay auction:
Description:
Introduced in 1998, the Quintet set the standard for big sound from small speakers, moving on to become our best-selling surround sound system of all time. Now in its fourth generation, this popular setup adopts both acoustic and aesthetic improvements.
Dynamic five-channel surround sound package
Exclusive XT Horn offers greater detail and wider dispersion
Powerful woofers produce room-filling bass
Latest crossover design delivers smoother response
Clean modern design complements today's HDTVs
Improved wire management for discreet on-wall installations
Matching SW-350 subwoofer sold separately
Since its inception the Quintet has been the biggest sounding small system on the home theater market. It’s also a product that takes style very seriously. So when our engineers set out to refresh this product they decided it had to look and sound better than ever—and does it!
The Klipsch Quintet bundles four speakers and a center channel together. Two of the speakers serve as front left and right main channels while the other two operate as rear surrounds. The magnetically-shielded center channel delivers crisp dialogue and precise imaging.
Continuing a mission that began in 1946 with our first horn-loaded speakers the latest Quintet advances our classic proven technology to new levels of sophistication and brilliance. It features XT MicroTractrix™ Horn technology—an all-new design that allows these small speakers to deliver amazing detail full-bodied sound and a wider soundstage than ever before.
In addition to letting you experience concerts that stir your soul films that put you among the cast of characters and games that put you in the middle of the action, the Klipsch Quintet is all about flexibility, installation ease and style.
Unlike similar priced systems, the Klipsch Quintet features high-quality five-way binding posts that accept heavy gauge wire, spade connectors or banana plugs.
Each speaker has a swiveling pedestal base that doubles as a wall bracket. We’ve added improved wire management for on-wall applications. Feed your wires through the small hole on the speaker base for a clean, discreet installation.
SPECIAL NOTE: If you wall mount your system, be sure to use the included hex wrench to loosen the screws on the back of the speaker before adjusting the base—failure to do so will strip the screws and cause the speaker to droop. Once you’ve got the desired mounting position, simply re-tighten the screws with the hex wrench.
The center channel can also be wall mounted by fastening a compatible aftermarket wall bracket to its ¼”-20 threaded insert.
Regardless of where you put it, the system has a clean, modern appearance that blends nicely with any décor. It features a satin black finish and black cloth grilles—a color scheme that beautifully complements today’s HDTVs.
With the Klipsch Quintet, great looks and great sound have never been this closely in tune!
SPECIFICATIONS
BUILT FROM: 2009
CROSSOVER FREQUENCY: Satellite: 3700Hz
Center: 3100Hz
DIMENSIONS: Satellite: 8.3" (21.1cm) H x 5" (12.7cm) W x 6.3" (16cm) D
Center: 5" (12.7cm) H x 12" (30.5cm) W x 6" (15.2cm) D
ENCLOSURE TYPE: Bass-reflex via rear-firing port
FREQUENCY RESPONSE: Satellite: 120Hz-23kHz
Center: 125Hz-23kHz
HIGH FREQUENCY HORN: 90(o) x 40(o) XT Micro Tractrix Horn
MIDRANGE: One 3.5" (8.9 cm) magnetically shielded woofer
MOUNTING: Satellite: Base swivels for on-wall mounting via keyholes
Center: Threaded insert
NOMINAL IMPEDANCE: 8 ohms compatible
POWER HANDLING: Satellite: 50 watts (200 watts peak)
Center: 75 watts (300 watts peak)
SENSITIVITY: Satellite: [email protected] volts/1 meter
Center: [email protected] volts/1 meter
TWEETER: One .75" (1.9 cm) neodymium magnet compression driver
WEIGHT: Satellite: 3.5 lbs (1.6 kg)
Center: 5.5 lbs (2.5 kg)
Ttt
Bump - Price lowered to $215 shipped.
Bump
ttt
Discussion Starter · #6 ·
Accepting offers.
Discussion Starter · #7 ·
ttt
Discussion Starter · #8 ·
ttt
Discussion Starter · #9 ·
Still have these. Someone take them off my hands.
Discussion Starter · #11 ·
Thanks. I might have one of those for sale, if you're interested.
Discussion Starter · #12 ·
Ttt
Discussion Starter · #13 ·
ttt
shoot me your lowest. I dont need them persay, but could use them for the computer.
Discussion Starter · #15 ·
PM Sent.
Discussion Starter · #16 ·
Bump
Discussion Starter · #17 ·
Bump
Discussion Starter · #19 ·
Fort smith, ar
Discussion Starter · #20 ·
Ttt
1 - 20 of 22 Posts
