SEE COMPLETE LISTING AND DESCRIPTION HERE:
For Sale 00/03 Cobra Clone Fully Built Street/Track Monster Kenne Bell - Ford Mustang Forums : Corral.net Mustang Forum
SEE PICTURES HERE
Library Slideshow by petermacmaster | Photobucket
For Sale is my 1999 Mustang GT/2003 Cobra Clone Street/Road Race Track Car.
With all of the parts in this car and the labor to build it, I have at least $100,000 invested in this car. It has been a fun journey for me over the years, and an expensive one, but I must let her go.
This would be a great opportunity for someone to get into this level of a car for a FRACTION of the money I have invested.
I am going to ask $25,000 for the car including all of the spare parts, body components, wheels and tires ect. I will humor trades.
Please only contact me if you are serious and have cash to purchase. Please do not send me wasteful emails. If you want to talk about the car, give me a call. Thank you for looking.
[email protected] or 678-362-5685
Engine:
.020 Overbore Built Engine
Diamond 11cc Dish Pistons
Manley Rods
Stock GT Crankshaft
Ford Racing SVO Heads w/ 5 Angle Valve Job
Canton High Capcity Oil Pan
ARP Head and Main Studs
Accufab Large Bore Single Blade Throttle Body
Comp Cams Camshafts
Comp Cams Beehive Springs
High Flow Oil Pump with Billet Oil Gears
Kenne Bell Flat Machiened Harmonic Balancer
Lightning 90mm MAF
Fluidyne Radiator
Castrol TWS 10w60 Motor Oil
New Battery
New Factory Replacement Starter
New Timing Chain Guides, Flapper Arms, Tensioners
New Alternator
Canton Oil Cooler with Stainless Braided Oil Lines
Canton Remote Oil Filter Kit
New Power Steering Pump
New Oil Pressure Switch
SCT Chip
New Water Pump
Cobra Increased Airflow A/C Condensor
New A/C Accumulator/Drier
Billet Timing Gear
New Coolant Hoses
New Coolant Tank
JLT High Boost Cold Air Intake
Ignition System:
MSD Coils
MSD Spark Plug Wires
NGK BR7FE Plugs
Power Adder:
Kenne Bell 2.6L Twin Screw Supercharger 15 PSI
Canton Aluminum Heat Exchanger Tank
PI to NPI Aluminum Adapter Plates
Upgraded Aluminum Heat Exchanger 26"x7"x3.5"
Fuel System:
Veyron High flow in tank pump
60lb/hr Fuel Injectors
Areomotive Fuel Pressure Regulator
MMR Billet Fuel Rails for KB Supercharger
Upgraded -8 Fuel Feed Line, Aeromotice Fuel Filter, Pressure Gauge and Fittings
Exhaust:
BBK Long Tube Headers
VRS X-Pipe (no cats)
Magnaflow Stainless Steel Cat-Back Exhaust
New Bosch O2 Sensors
Suspension:
Maximum Motorsports K-Member
Maximum Motorsports A-Arms with Derlin Bushings
Maximum Motorsports Race MM3 Struts
Maximum Motorsports Race MM3 Shocks
Maximum Motorsports Front Swaybar Bushings
Maximum Motorsports Steering Shaft
Maximum Motorsports Front Coil Over Kit with 500lb Hyperco Springs
Maximum Motorsports Rear Coil Over Kit with 700lb Hyperco Springs
Maximum Motorsports Bumpsteer Kit
Maximum Motorsports Cross Axis Kit
Maximum Motorsports Subframe Bushings
Maximum Motorsports Aluminum Adjustable Differential Mount
Maximum Motorsports Rear Tire Rod and Bumpsteer Kit
Maximum Motorsports Rear Swaybar Endlink Kit
Maximum Motorsports Rear Derlin Control Arm Bushings
Maximum Motorsports Caster Camber Plates
Maximum Motorsports Solid Rack Bushings
Complete IRS from 2003 Cobra
New Power Steering Rack
Eibach Rear Swaybar
Maximum Motorsports Subframe Connectors Full Length
18x9 and 18x10 Gloss Black Saleen Replica Wheels
Nitto Invo 275/35/18 and 295/30/18 Tires
18x9 and 18x10 Gloss Black Forgestar CF5 Wheels
Nitto NT01 275/35/18 and 315/30/18 Tires
Brakes:
Stoptech Big Brake Kit (Front) with 14" (2) Piece Rotors
Stainless Steel Braided Brake lines
Front Pagid Yellow Race Brake Pads
New Hydroboost Unit
New Stock Cobra Rear Calipers and Caliper Brackets
Motul Brake Fluid
Hawk Rear HP Plus Brake Pads
Slotted Vented Cobra Rotors
Hurst Line Lock Kit
Driveline:
Stock 2003 Cobra Tremec 6-Speed Transmission
Speed Cal Speedometer Calibrator
SPEC Stage Two Kevlar Clutch
FRPP Aluminum Driveshaft
Metco Driveshaft Safety Loop
Steeda Aluminum Clutch Quadrant
Steeda Firewall Clutch Cable Adjuster
3.73 FRPP Ring and Pinion Gears
Torsion Differential
DSS Level 2 Upgraded Half Shafts with Road Race Prep, Freshly Rebuilt
Steeda Tri-Ax Shifter
Reverse Lockout VSS/OSS Control Box
Motul Gear Oil
Steeda Adjustable Clutch Cable
Synchromesh Trans Fluid
Interior:
Classic Soft Trim FR500 Seats
FR500 Steering Wheel
Cobra Gauge Cluster
35th Anniversary Shifter Knob
UPR Billet Items
Kenwood Garmin Navigation Head Unit
Polk Audio Speakers
Coustic 12 Inch Subwoofer
Alpine Amplifiers
Saleen Aluminum Pedals
35th Gauge Bezel
Maximum MotorSports 4-Point Bolt in Roll Cage
FRPP Boost Gauge
AeroForce Interceptor Gauge with added Oil Pressure and Temperature
Dual Pillar Pod
Schroth 6 Point Profi 2 Harnesses
Full Dynamat Front to Rear
Window Tint
Exterior:
2003 Cobra Front Bumper with Fog Lights
2003 Cobra Side Scoops
2003 Cobra Rocker Panels
2003 Cobra Rear Bumper Cover
2003 Cobra Side Mirrors
2000 Cobra R Functional Front Bumper
New Black Bezel Headlights
APR Carbon Fiber Functional Adjustable Rear Wing
Tiger Racing Functional Heat Extractor Lift off Race Hood
AeroCatch Plus Flush Hood Latches
Custom Tangelo Orange Paint Job and Finish Work
New Windsheild
Steeda Cowl Hood
SEE PICTURES HERE
Engine:
Manley Rods
Stock GT Crankshaft
Comp Cams Camshafts
Lightning 90mm MAF
Fluidyne Radiator
New Battery
New Alternator
SCT Chip
New Water Pump
Billet Timing Gear
New Coolant Hoses
New Coolant Tank
Ignition System:
MSD Coils
NGK BR7FE Plugs
Power Adder:
Fuel System:
Exhaust:
Suspension:
Eibach Rear Swaybar
Brakes:
New Hydroboost Unit
Motul Brake Fluid
Hurst Line Lock Kit
Driveline:
Motul Gear Oil
Interior:
Cobra Gauge Cluster
UPR Billet Items
Polk Audio Speakers
Alpine Amplifiers
35th Gauge Bezel
FRPP Boost Gauge
Dual Pillar Pod
Window Tint
Exterior:
New Windsheild
Steeda Cowl Hood
