Can someonne tell me how to turn off the traction control? I can't seem to find it. Thank you
+1.There should be a button that says ESP, push that to turn off the traction control. I think its on the dash towards the top bu the hazzard flasher button.
You forgot the magic words :laugh:Put your car in park and turn the engine off. With the engine off, depress the accelerator pedal three times. Now tap your head twice and rub your belly four complete circles. Turn car back on and go.
That is so ignorant.Put your car in park and turn the engine off. With the engine off, depress the accelerator pedal three times. Now tap your head twice and rub your belly four complete circles. Turn car back on and go.
Video?Found it! Thank you. This car does awesome burnouts! It can burn rubber for half of a block. So much smoke you couldn't see behind you. I will video one tomorrow. I can see the biggest expense for this car is going to be rear tires.![]()
How much did the ride change with 22"s? Did it get very hard?Haha! The rear tires are going to wear so fast! I have the 63 and go through rear tires quick! When I had the stocks, I was going through rears every 3,000 - 4,000 miles. I put Pirelli's on my 22's and have not had to replace them as often. Pirelli's are a bit harder then the stock Yokohama / Continental / Michelin brand.
