1 - 13 of 13 Posts
All of a sudden no sound at all in my system. Car is running works fine, shut car down and come back later, no sound.
Unit is a pioneer avic F90BT and seems to be working fine otherwise. Amp is an alpine PDX5 running all 5 channels. Amp is on and all lit up. Any ideas??
i looked at the pin out. doesnt appear you have one. but its a cable that you can wire to a switch, that will mute the audio.
You can get an ipod with a 3.5mm to rca and plug it right into the amp to test it. i would fiddle with the plugs in the back. make sure they are fully plugged in. have you also checked the settings to make sure that the output is set right?
sounds like either the amp has blown or a speaker cable is touching metal somewhere causing a short! the easiest way to find out if its a short is to disconnect 1 speaker at a time but make sure to do it while the unit is switched off. If you have a multi meter then you can also check each speaker! normally the amp will go into protection mode if this happens and you will have a warning lamp on the amplifier itself.
Discussion Starter · #8 ·
that!s what i did. 3.5 headphone into 2 rca's going into amp inputs. i figure i would at least get some sort of sound. got nothin. amp is lit up like it is working. everything has been running great for almost 2 yrs.
Discussion Starter · #11 ·
it never showed anything but blue but I found one of the sub wires where it goes into the amp connector was loose. i tightened all of the allen screws on the speaker plugs on the amp also. started it back up, works fine right now. thanks for all the help guys. at least i know its somewhere in the amp or amp connections if it happens again.
1 - 13 of 13 Posts
