1 - 15 of 15 Posts
Audi RS3 Sportback Revealed With 340-HP | AutoGuide.com News
With the current A3 model nearing the end of its production cycle, Audi will send the car out with a bang, announcing an all new RS3 model. Putting even the Golf R to shame, the RS3 Sportback produces an incredible 340-hp and 332 ft-lbs of torque from the same turbocharged 2.5-liter 5-cylinder engine found in the TT-RS. Mated to a 7-speed S tronic dual clutch transmission and using Audi’s quattro all-wheel drive system the car can blast to 62-mph in just 4.6 seconds.
Added grip and improved handling come thanks to 19-inch wheels with 235/39/19 front tires and 225/35/19 rear tires (yes, the front tires are wider). That matches up with a front track that is just over an inch wider as well, while the overall ride height has been dropped by one inch. An ultra-precise 16.2:1 steering ratio makes the RS3 really turn when you point it.
Helping to cut weight, the wider front tires are now made of carbon fiber.
Improved braking is also a part of the package thanks to 4-piston front brake calipers with massive 14.57-inch rotors (370mm), while the rear brakes run 12.2-inch rotors.
The exterior of the RS3 isn’t quite as dramatic as past RS models, with the fenders bulging less, still, there’s a massive front grille with more aggressively designed side intakes. Side skirts, matte-aluminum mirror housings, a roof spoiler, black diffuser, two exhaust pipes and several RS3 badges round out the design.
Inside, it’s pure Audi luxury with Nappa leather, silver stitching and piano black or Aluminum Race trim, with a flat-bottom steering wheel.
Audi has made several nods to enthusiasts with this car, including a stability control system that can be turned completely off, while including a lap timer in the driver information screen. Plus, a Sport button activates flaps in the exhaust system to really let the engine howl.
Unfortunately, you’ll have to be a rich enthusiasts to afford the RS3 Sportback, with the price set at 49,900 Euros. That’s $68,000… yikes.
Sadly, that number is mostly irrelevant on this side of the Atlantic as Audi has announced now plans to sell the RS3 in North America.
67,000... puff, puff, pass
thats close to the sticker of an RS4
kind of expensive... but i bet it'll be really fast and really fun to drive.
1 - 15 of 15 Posts
