1 - 6 of 6 Posts
On my ADVO5 right front wheel I loose about 2 - 3 PSI per month. Is that kind of normal with multi piece wheels? This is my first time buying wheels that are not one solid piece, so not sure what to expect.
Topless SL65 With ADVO5DC by WIKD Cars & Such, on Flickr
This is most likely a tire/bead issue, but I believe there is also a silicone seal on the wheel that could have been damaged by your tire installer.
Discussion Starter #5
Hi, please contact us right away if you find that there was an issue with the wheel.
Your point of contact will be [email protected].
Yes I was thinking of calling, but was not sure if such a slight leak was somewhat normal or not. I have to fill all of them a little every couple months, but the right front more often. Let me see how the pressure is this weekend compared to the left front. Such a small leak may be difficult to find too.
No problem. Please feel free to give us a call any time.
(305)238-0058
Ask to be transferred to Sean.
Most tire shops will have a "Dunk Tank" they set your wheel inside water. If you see any bubbles then you have an air leak.
1 - 6 of 6 Posts
