1 - 14 of 14 Posts
This particular Edizione Technica Superleggera was featured in our VF760 brochure recently along with another black 2013 LP570 Supercharged SL.
The car was brought directly to our facility from Lamborghini Newport Beach with only 50 miles on the ODO. This is the owner's 2nd VF supercharged Gallardo.
We will be updating this thread as pictures and information become available.
Still fresh from the factory
Front mounted Heat Exchanger Installation
Twin front mounted Bar and Plate heat exchangers for maximum surface area.
Passenger side is shown installed w/OEM shroud and water lines connected
Driver side is shown below without the OEM shroud and Cold side outlet not yet connected
Illustration of water flow through Passenger side radiator w/custom mounting bracket installed.
The bracket and assembly shown below was engineered to allow our radiator to fit with the factory engine radiator and the A/C condenser within the OEM shroud
Installed
Air-to-water cooling system diagram
Discussion Starter · #7 · (Edited)
Custom MAF housings with K&N air filters assembled
Although very simple looking pieces, countless hours and resources went into creating our VF-Spec custom harmonic dampener and auxiliary alternator drive pulley. Putting together simple billet pulleys was not enough. Precision engineered and perfectly balanced, these pieces come together to provide factory-like drivability and feel at whatever RPM you are driving at.
Ready for S/C assembly to be installed
Once the water lines for the cooling system are plugged into the fittings above (pictured with caps) The inlet and final touches are all that remain.
Discussion Starter · #9 ·
With all of the major parts installed, all that's left are the final touches on the Supercharger assembly.
Custom MAF housings installed in airbox
Vacuum lines fitted and airbox connected to supercharger inlet
Final installation all tied up!
Videos will be up soon!
cost?
1 - 14 of 14 Posts
