Results 1 to 7 of 7
Thread: Bentley GT starting problems
    2913bhp is offline Junior Member
    Aug 2010
    Default Bentley GT starting problems
    Hey guys,
    I tried to start my 05 Bentley GT today and even though the car has full electrical power, it doesn't crank at all when i turn the key. I don't think it's an electrical issue but i'm not positive. Has anyone experienced anything like this before?
    Thanks in advance.
    Padholdr's Avatar
    Padholdr is offline Member
    May 2011
    Tacoma,Wa
    Wow, could be so many things. I would do a battery test first. Make sure the car is in park too. I had a friends gt have a similar issue and it was just the battery though.
    STIG's Avatar
    STIG is online now Senior Member
    Nov 2010
    So-Cal 562
    Definitely start at the battery as mentioned by Pad. Maybe one of your terminals is disconnected.
    Instagram @simplyuzzi
    Coming to a track near you.
    SHO-TYME is offline Junior Member
    Mar 2011
    If the car sits for too long, the computers in the car will run the battery down. You need to get the battery maintainer from Bentley and keep it on the car when not in use for long periods of time.
    Also, the car has an auxilary battery on it, (Right corner of trunk.),put the key in the ignition, turn it to the left, hold for several seconds and turn back to the right and try to start the car. This will activate the auxilary battery to start the car.
    D2FORGED's Avatar
    D2FORGED is offline Silver Sponsor
    Jan 2009
    Plainview, NY
    Have everything checked, but if it needs a starter its very expensive (the engine/tranny have to be pulled to replace the starter)
    D2FORGED Wheels | Inspired by Excellence. Driven by Passion. Defined by Distinction.
    Website: http://www.d2forged.com
    Facebook: http://www.facebook.com/d2forged
    Twitter: http://www.twitter.com/d2forged
    Gallery: http://www.d2forged.com/v2/gallery
    Contact Information: 800 913 3513 | info@d2forged.com
    Mar 2011
    Quote Originally Posted by 2913bhp View Post
    Hey guys,
    Thanks in advance.
    Where are you located at?
    djantlive's Avatar
    djantlive is offline Senior Member
    Nov 2009
    could be starter, fuse, ignition coils/module.
    may want to start with fuse first. check the battery power.
