Results 1 to 2 of 2
07-06-2011, 11:52 PM #1
Finally a SOLUTION for retrofitting 2010+ MY LED Rear Tail Lights on Full-Size RR
Hey guys,
After much banging my head against the wall...I have found a one stop PLUG'N'PLAY solution for fitting the rear tail lights. I have a source out in the UK that sells a complete plug n play kit that solves all the following issues:
1) Rear fog lights always ON
2) Flickering Lights
3) blinker speed
4) brightness of side lights
This box is the only one of its kind and so simple to fit, it comes with full diagram on how to fit. To give you some idea of how long it takes to fit, ten minutes should do it, that simple, No Auto electrician needed.They are professionally built by a bloke in the UK.
What you get: Two Electronic boxes one per side. They are made to order.
If you want me to order a set for you let me know. The price is $350 per set (two electronic boxes). No need to waste money on labor from an electrician that will charge you up the ying-yang...this will solve all your problems...I thought I would share with all the people interested in upgrading your new tail lights to 2010+ MY ones.
Thanks. PM me if interested.
Here is a picture of the unit...
2008 Range Rover SC Westminster
(2010+ MY Conversion)
2001 Range Rover 4.6 HSE
285/70R16 Nitto Trail Grappler's
2" OME Lift w/ Fox Reservoir Shocks
Tom Woods Driveshafts
Custom Stereo
07-06-2011, 11:59 PM #2
I am ordering 5 sets this week. I may order 10 sets if I have enough interest. If you want to buy more than one set I can work out a better deal. Let me know. I know there have been tons of people looking for a solution like this...easy install with no cutting and dicing.
Thanks2008 Range Rover SC Westminster
Custom Stereo
