Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: DLP or LED powered DLP?
    Jimbo's Avatar
    Jimbo is offline Senior Member
    Chicagoland
    Default DLP or LED powered DLP?
    Thoughts? I'm trying to decide between 3 TVs:
    65" DLP
    67" LED powered DLP
    73" DLP
    What is different about the LED powered? Is there any benefit?
    "You need people like me so you can point your f*cking fingers, and say, 'that's the bad guy!'"
    -Scarface
    Jeremy's Avatar
    Jeremy is offline Senior Member
    Chicago
    Moving parts = Scary to me
    EDIT: Post 666 FTMFW!
    Jimbo's Avatar
    Chicagoland
    moving parts scare you, however 666 post does not... hmmm
    -Scarface
    Jeremy's Avatar
    Chicago
    Nah, it came up in one of your threads, it seemed logical to me...
    StreetPreacher's Avatar
    StreetPreacher is offline Senior Member
    Jun 2008
    Hamilton
    With LED you shouldn't ever need to replace the light source, but I haven't done much research on whether there are any other issues with the new LED based DLPs.
    I really like the idea of not having to replace bulbs at ~$300 a pop so LED would be my choice.
    The Phatlight technology is impressive.
    http://www.luminus.com/
    Quote Originally Posted by Jimbo View Post
    The LED version uses RGB LED lights instead of a light bulb and a colour wheel. The benefits are that the LED light source should last for the life of the set (no replacing bulbs every few thousand hours), and since there's no colour wheel there's no (little?) chance of seeing 'rainbows'.
    Bacchus's Avatar
    Bacchus is offline Senior Member
    Jul 2008
    Memphis
    Need more info: if you're not willing to post the models under consideration PM me.
    Loves wine, women and song
    Frisco's Avatar
    Frisco is offline Junior Member
    Jul 2008
    A lamp based DLP set uses a light bulb that has a spinning color wheel filter in front of it to produce the three primary colors; whereas, a LED based set has 3 LEDs that are turned on and off at the same speed to mimic the effect of the color wheel. HID lamps like this are typically spec'd with approximately a year of useful life when operated continuously, and the spinning color wheel filter is also subject to failure due to failure of the motor assembly. LED lifetime is typically 5-10X longer than a comparable bulb, and the net result is a set that requires less maintenance. Phlatlight LEDs are similar to regular LEDs, except that the light produced is focused better out of the face of the chip due to the design so the efficiency is a bit higher.
    Jeremy's Avatar
    Chicago
    Like I said, no moving parts for the win
    Jimbo's Avatar
    Chicagoland
    73" DLP:
    Model: WD-73735
    65" DLP:
    Model: WD-65833
    67" LED DLP:
    Model: HL67A750
    -Scarface
    icruze's Avatar
    icruze is offline L4P Consigliere
    Chicago
    dlp = ftl
    2011 Audi S4
    Porsche 997S (Sold)
