Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Humidor problems
    GToakSnob's Avatar
    GToakSnob is offline Member
    May 2009
    Centerville, Ohio
    Default Humidor problems
    Ok so my humidor used to sit around 68 to 70%. Now it has dropped down to 59%. I am using the gel cups for humidity. they have always worked well but now its not working.. Am I doing something wrong?
    Jun 2009
    I'm on a boat...
    how full is the humidor?
    what's the temperature and humidity of the room that the humidor is in?
    is there direct sunlight on the humidor?
    did you add any new (and dry) cigars to the humidor lately?
    lots of things can affect the humidity but they can all be corrected.
    f3d's Avatar
    f3d
    f3d is offline Member
    Jun 2009
    NYC
    Quote Originally Posted by themadhatter View Post
    Also check how tight the seal is on the humidor.
    open the lid, lay a dollar bill across the seal and close the lid.
    If it rips you have a gangster seal. If it pulls out really easily you have a poor seal and will have problems keeping the RH and temp steady in the humidor, and if it pulls out but takes a bit of effort (yet doesnt feel like its going to rip) you should be ok.
    The environment the humidor is in plays a large part in how it acts inside as madhatter mentions.
    I would also look into getting Boveda humidity packets
    I'm no expert, this is all stuff people have mentioned to me along the way...
    Whitlock is offline Senior Member
    Jul 2008
    ATL
    How would this affect the humidity? I'm having the same problem as mentioned above, but mine is not as full as it usually is. I guess I need to buy more cigars?
    PadronCubans's Avatar
    PadronCubans is offline Gold Sponsor
    Sep 2009
    Miami, FL.
    +1 I would try all the tips stated above!
    www.padron.com
    www.facebook.com/JeffPadron
    "When Padrón is on the label, quality is a matter of family honor." -Jose O. Padrón
    "Some work hard, others have a hard time working." -Jeffrey O. Padrón
    "Faster, Faster, until the thrill of speed overcomes the fear of death." -Hunter S. Thompson
    LoveTheGoodLife's Avatar
    LoveTheGoodLife is offline Junior Member
    Jan 2010
    Not trying to hijack your thread GT, but what kind of hygrometer are you using? And do you prefer one type over another?
    For that matter, does anyone prefer one type over another?
    Thanks.
    ackroydb's Avatar
    ackroydb is offline Senior Member
    Mar 2009
    Portland
    Gel cup only work for so long (year to year and a half). After a while they stop absorbing water. It could just be that they are out of life. When you fill them, are they still absorbing all the water that you are pouring into them?
    SoJersey05V's Avatar
    SoJersey05V is offline Senior Member
    Jan 2009
    +1 on above comments about the seal of the humidor
    Jun 2009
    I'm on a boat...
    Quote Originally Posted by whitlock View Post
    as I've been taught. there is the 70/70/70 rule for keeping a humidor and it's contents happy:
    70% humidity
    70F
    at least 70% full
    an empty humidor is more difficult to regulate then one that has a healthy quantity of cigars in it.
    JLasher22443's Avatar
    JLasher22443 is offline Senior Member
    Jun 2008
    Virginia
    70% humidity
    70F
    at least 70% full
    Great Comment! This is definitly the way you want your Humi to be, give and take a bit on the temp and humidity.
    But in my opinion I would check everything that has been stated above first. Then maybe switch up the way you humidify your humidor.
    I only trust quality Hygrometers and Humidification Systems when it comes to my cigars. I would suggest Diamond Crown or Xikar second to them. I have all Diamond Crown gear and check at least once a week on my cigars and never have a problem. Here is a link.
    Diamond Crown Exquisite Collection
    Jason
    "If your wife doesn't like the aroma of your cigar, change your wife.", Zino Davidoff
    "I drink a great deal. I sleep a little, and I smoke cigar after cigar. That is why I am in two-hundred-percent form.", Winston Churchill
    “Happiness? A good cigar, a good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle.” George Burns
