Results 1 to 3 of 3
02-07-2012, 07:56 PM #1
Junior Member
- Feb 2010
- italy
- 6
gallardo remote control for soft top
is it possible ?
alex
02-08-2012, 02:21 AM #2
i haven't heard of it.
04-11-2012, 08:43 PM #3
Junior Member
- Mar 2011
- Doncaster, UK
- 12
Anything would be possible, you just have to find the restrictions. Not having owned a gallardo soft top, I wouldn't know what these were, but it could be done. Restrictions could be the ignition needing to be on to operate it. You would have to find a way to do this if so, or find and alternate workaround. But this could be done crudely by hijacking onto the window controls through the keyfob. On most vehicles, you can hold down the unlock doors button, and all the windows will drop. You would just need to find the relay for the soft top, and where the signal originates from when the button is pressed. Then combine the two so the signal activates the relay to drop the roof. Or, set up a full system in place with a separate fob, which would be safer, as the crude way could encounter problems such as the roof dropping every time the windows are lowered. If you own one, consult an auto electrician and put some plans in place. If it hasn't been done before, be the first to do it.
