Results 1 to 10 of 13
Thread: car stereo help
09-15-2010, 11:30 PM #1
Senior Member
- Jul 2008
- New Orleans LA.
- 1,234
car stereo help
All of a sudden no sound at all in my system. Car is running works fine, shut car down and come back later, no sound.
Unit is a pioneer avic F90BT and seems to be working fine otherwise. Amp is an alpine PDX5 running all 5 channels. Amp is on and all lit up. Any ideas??
09-15-2010, 11:36 PM #2
did the mute cable short out by chance?
also, what audio source are you using?
have you tried ipod, cd, radio?JEEP: The dirtiest of the four-letter words
OIIIIO
09-15-2010, 11:45 PM #3
Lights are on but nobody home?
intermitant cutting in and out or just dead?
09-16-2010, 12:00 AM #4
Senior Member
- Jul 2008
- New Orleans LA.
- 1,234
just dead, no sound from all sources. any way I can check just the amp? or just the unit?
what's a mute cable?
09-16-2010, 12:02 AM #5
Senior Member
- Jul 2008
- New Orleans LA.
- 1,234
i plugged a mini headphone to rca from my iphone into one of the amp rca imputs to see if I got at least some sound, a pop hum or something got nothin
09-16-2010, 12:03 AM #6
i looked at the pin out. doesnt appear you have one. but its a cable that you can wire to a switch, that will mute the audio.
You can get an ipod with a 3.5mm to rca and plug it right into the amp to test it. i would fiddle with the plugs in the back. make sure they are fully plugged in. have you also checked the settings to make sure that the output is set right?JEEP: The dirtiest of the four-letter words
OIIIIO
09-16-2010, 12:11 AM #7
sounds like either the amp has blown or a speaker cable is touching metal somewhere causing a short! the easiest way to find out if its a short is to disconnect 1 speaker at a time but make sure to do it while the unit is switched off. If you have a multi meter then you can also check each speaker! normally the amp will go into protection mode if this happens and you will have a warning lamp on the amplifier itself.
09-16-2010, 12:15 AM #8
Senior Member
- Jul 2008
- New Orleans LA.
- 1,234
that!s what i did. 3.5 headphone into 2 rca's going into amp inputs. i figure i would at least get some sort of sound. got nothin. amp is lit up like it is working. everything has been running great for almost 2 yrs.
09-16-2010, 12:18 AM #9
then either the amp is dead, or maybe in protection mode.
or like said above, you have a shortJEEP: The dirtiest of the four-letter words
OIIIIO
09-16-2010, 12:30 AM #10
What colour is the square indicator light showing? solid or flashing aswell...
Blue is Normal
Red is Protection mode - caused by voltage drain,dead short on a cable or it's got too hot.
Flashing Red is High Temp cut out.
