Results 1 to 2 of 2
Thread: Hardwire Power Inverter
    Forfend's Avatar
    Forfend is offline Senior Member
    Dec 2009
    North Suburbs, Chicago
    Default Hardwire Power Inverter
    I'm planning on hard wiring my power inverter in my car. The inverter is rated at 400 watts continuous with a peak surge of 800 watts. Would this setup be correct and safe? Possibly a better setup out there?
    12.6v car battery
    10 Ga wire (15ft or so)
    40 amp fuse located next to battery
    Since I will never hit 800 watts, if I use 300 I'll be surprised, I figured using a fuse that can handle 480 watts should give me plenty of available power?
    East bound and down, loaded up and truckin',
    we're gonna do what they say can't be done.
    famous autosports is offline Senior Member
    Nov 2008
    woodland hills
    should be fine with that
