Results 1 to 8 of 8
07-25-2010, 01:41 AM #1
Please help. Having trouble connecting iPod/iPhone to Kenwood DNX-7100
Hi,
I am experiencing some issues with my ipod/iphone connectivity on my Kenwood DNX7100. When I plug my iPhone into the data cable it charges my iPhone but I am unable to access any music or videos off of it thru the head-unit. As for as I know I have the latest software update on the unit and have the proper cable. Any advice would be greatly appreciated.
-JamisonLast edited by DeepindebtJD; 07-25-2010 at 01:45 AM.
07-25-2010, 02:04 AM #2
Unit reads "disconnected" at all times. Also, I am using a KCA IP301 cable.
07-25-2010, 03:27 AM #3
did it ever work and this is all of a sudden? or has it never worked?
what iphone and what OS?
07-25-2010, 08:03 PM #4
^^long story short is that I have never had this particular head unit hooked up with the iPod cable. I owned the exact same unit prior to it being stolen and it worked fine with my 2g iPhone running 1.1.4 (I think that's right).
My replacement unit will not work and never has worked that old iPhone nor with my new iPhone 4 running 4.0.
07-25-2010, 11:00 PM #5
Junior Member
- Jul 2010
- Sherman Oaks,Ca
- 1
From my experience a couple of days ago,the Kenwood 7100 uses the KCA-IP300v
KCA-IP301 is for Newer Units,but they do look very alike...
07-30-2010, 08:17 PM #6
Kenwood will have a software update soon for Iphone 3g and 3gs running ver 4.0 software they are aware of the problem. The update will be via thumb drive thru USB. Keep your eye out on Kenwoodusa.com/support. They will post it there.
07-30-2010, 09:47 PM #7
the only way to get my iphone 4 to connect to my kenwood unit is to open "ipod" on the phone, hit the home button, double tap to open multitask list, press and hold "ipod", close it, then plug the cable in. Kinda sucks, but works every time that way.
08-02-2010, 05:35 PM #8
Thanks for the comments and suggestions guys. I'm goon to try an locate the older model cable today and see if I can't get things going.
