Results 1 to 10 of 10
Thread: question for the audio installers here.
    w210e55 is offline Junior Member
    Jun 2008
    Dallas
    Default question for the audio installers here.
    Hey Guys,
    I currently drive a 05 350z roadster and am planning on installing a JL audio 500/1 and 300/2 amp in my car. Am I going to need to run a capacitor or will I be fine running without?
    thanks in advance.
    Infamous's Avatar
    Infamous is offline Senior Member
    Sep 2008
    NYC
    JL amps are very power hungry. You could throw a cap in there, but most of the time I would just get a small kinetik battery to add onto the system.
    Oct 2009
    Pennsylvania
    No, do not run a cap. Part of the reason that JL's are so good is because they have enough internal power that you don't need one. You probably won't even need a small secondary battery.
    pektel is offline Member
    Jun 2010
    I would first get a higher output alternator, and upgraded wiring before adding something that will put even more draw on the electrical system.
    Christiancoach's Avatar
    Christiancoach is offline Senior Member
    Dec 2009
    I have a JL Audio 900/5 and running it full tilt doesn't dim my lights or affect the voltage at all. I have no power upgrades. Caps are a waste IMHO unless you are a serious SPL competitor.
    The newest JL Audio amps are not power hungry.
    2008 Evoke Grey Holden SS-V
    SV6 Spoiler, Brembos, Vector Motorsports Tune, Kooks LT Headers, Corsa Catback, Roto-Fab CAI w/radiator cover, Tinted Windows, and Tails, Vossen VVS-082 Staggered 20's, Holden Splitter, Orange Halo's, Sport Steering Wheel, Holden Shifter, Holden Rebadge, GXP Diffuser: Gloss Black, Engine Cover: Tri-Color, Calais Trim, Pedders XA Coil Overs, Sport Pedals, Sharkfin Antenna, Spare w/Jack Kit, Holden Rubber Mats and Trunk Lip Protector
    SKilledA's Avatar
    SKilledA is offline Senior Member
    Jan 2010
    Al and Ed's West LA
    According to JL Audio Do Not put a cap on there amps. Just upgrade your stock battery to an Optima Red top 1000cca and you good. I do it all day every day.
    UNIQUE AUDIO's Avatar
    UNIQUE AUDIO is offline Junior Member
    Dec 2009
    DESTIN,FL
    i agree, if you want to, just do a red top optima, dont change your alternator or a cap.
    we had a shop g35 with a whole lot more power and just did a battery swap and it was good.
    cnbelcher's Avatar
    cnbelcher is offline Junior Member
    Nov 2009
    Charlotte, NC
    I prefer not to run caps...used them but just not a fan. Do a Kinetic battery upgrade and replace your stock battery that can run your vehicle and cover you on the reserve needed to the extra ampere draw.
    If you intend to get crazy in the future the alternator is the option after that.
    Chris
    MECP Advanded Certified Installer
    Handling the Truth Carelessly
    reme's Avatar
    reme is offline Member
    Jan 2010
    Cleveland, Ohio
    I have a client that used to run that same set-up, I would recommend 1/0 awg power cable from the battery, and an Optima redtop, you will be more then fine. I don't know if you have that equipment already, but I happen to have those two amps used in my shop and I'm selling them cheep. LMK and good luck
    Ross
    Owner of several business that have yet to make any money
    Aug 2010
    Nehawka, Nebraska
    I would just make sure you get really good wiring, and maybe if it's really necessary, get a better battery.
    The greatest pleasure in life is doing what people say you cannot do - Walter Bagehot
