Results 1 to 9 of 9
Thread: Someone help me with a new build! A&E?
    unitedvisionary's Avatar
    unitedvisionary is offline Senior Member
    Aug 2008
    Milpitas / Fremont / Riverside
    Default Someone help me with a new build! A&E?
    So...
    I am building with 3 other companies (software / Hardware) joint venture on a secret audio setup hopefully to debute at CES in Jan...
    I am looking for a HD Monitor for the car use... anyone know any High Definition 720 or 1080 monitors from 10" - 14" available? if not.. whats available?
    Thanks in advance!
    UV
    Allyson's Avatar
    Allyson is offline Senior Member
    May 2009
    Newport Coast
    Please correct me if I am wrong ...but I have never seen one and do not really understand why you would want one (for your car) simply because you could not tell a difference. High-definition television (HDTV) yields a better-quality image than standard television does, because it has a greater number of lines of resolution. The visual information is some 2-5 times sharper because the gaps between the scan lines are narrower or invisible to the naked eye. The larger the size of the television the HD picture is viewed on, the greater the improvement in picture quality. On smaller televisions (less than 17-20 inch) there is no noticeable improvement in picture quality.
    There are smaller screens available (HD/HDI compatable) for video editing, broadcast, professional video and multimedia applications but they are going to run in the 3-5K range and would not be compatable with other applications (Navigation, Bluetooth, etc..) that you would desire in a vehicle...
    Allyson's Avatar
    May 2009
    Newport Coast
    That being said... I do have a an old 10' LCD monitor in the garage from our "pre" touch screen days that I will donate to the cause! If you are interested just let me know!
    RAWMEAN's Avatar
    RAWMEAN is offline THE ONLY MAN THAT CAN™
    Contact Elie at Al & Eds (our sponsor) if anything is out there he would know.
    Aug 2008
    Well yah.. you wont be able to really tell the difference with such a small screeen.. but wanted to do something quality wise similar to:
    Panasonic USA Pressroom
    but on a standable screen.
    i guess it is a WSVGA screen.. so something similar would work, but the quality is ridiculously amazing. anyone know something that like taht is under 14, 15" and is screen only? would want to retrofit this custom in front of the passenger.
    Thx in advance. Allyson, i PMed you lmk hehe.
    UV
    A-E's Avatar
    A-E
    A-E is offline Gold Sponsor
    Apr 2009
    As far as I know, for the 12v and mobile environment, 19" is as small as HD monitors go. That link you have is interesting but not a good application for custom install. I will keep an eye and ear out for any new updates on this issue.
    Elie Rothstein
    Al & Eds Autosound
    West Hollywood,CA
    elie@al-eds.com
    www.AE54.com
    AMGBiturbo's Avatar
    AMGBiturbo is offline Senior Member
    Dec 2008
    Wichita, KS
    Drivesoft had some pretty high res touchscreen lcds when they debuted, hit them up.
    Aug 2008
    Quote Originally Posted by AMGBiturbo View Post
    Interesting products. good recommendation i will loook into it. Thnks!
    UV
    Aug 2008
    Quote Originally Posted by A-E View Post
    Elie, do you know which kinds are available for the 12V 19" HD monitors?
    UV
