Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: F1 Cars Using 1.6L Four Cylinder Turbo Engines
  1. #11
    Bignmz04's Avatar
    Bignmz04 is offline Senior Member
    Dec 2009
    Quote Originally Posted by civic4982 View Post
    ^ expensive parts are needed to work accurately at those RPMs, the parts also need to be lightweight etc and of course reliability.
    taking in mind just one component like the pneumatic valves used would skyrocket the cost of any regular line of cars to reach those 20K+ RPMs that F1 engines were doing before.
    pneumatic valves are not that expensive or complex... ducatis have been using them on street bikes for quite some time. the next wave will be electro actuated valving. no cams needed.
    the main thing with high rpm usage are the wrist pins...they have more load on them than anything and control the load on the piston....you should see some of designs...crazy offsets on the pins to decrease friction. (i have a piston, ring, wrist pin. rod, iconel header, brake rotors, calipers, and sparkplugs and steering wheel from the petronas 3a engine used in a 1999 sauber c18)
    to stay up front..teams will still throw crazy money at these 4 bangers cost never goes down only goes up....this was shown in motogp...nomatter what changes they made to cut cost...it kept creeping up till DORNA stepped in and told em to spend away. this is supposed to be better...its formula 1!!...its about progress nor regress.
    if i wanted to see 4 bangers running around...i could just go watch the other formula races...
    Fortuna audax iuvat
  2. #12
    civic4982's Avatar
    civic4982 is online now Senior Member
    Nov 2010
    Texas
    ^ is the goal to cut costs or elevate the challenge to the driver and the engineer both?
    I think the latter is a reasonable conclusion as well.
  3. #13
    Turbology's Avatar
    Turbology is offline Senior Member
    CT
    Quote Originally Posted by Bignmz04 View Post
    and yes you honda civic/toyota celica boys....this tech will trickle directly down to you.
    Crossing my fingers for EJ20 F1 technology...
    Boost Is Better
  4. #14
    Bignmz04's Avatar
    Dec 2009
    cut cost....these engineers are so out there that a four banger especially with a turbo...wont challenge them for anything. I doubt the drivers will be challenged any more or any less than a current car will.
    Fortuna audax iuvat
  5. #15
    1stFeature's Avatar
    1stFeature is offline Senior Member
    Jun 2010
    Oregon
    Nooooo...I was hoping this wouldn't come true
    Quote Originally Posted by HazeMyth View Post
    Life was all bout suckin' tittays, takin' naps, and other people doing the dirty work after I shit myself.
  6. #16
    pcasey06's Avatar
    Nov 2009
    Palm Beach, Florida
    lame.
    Pat
    Current-
    Past-
  7. #17
    Turbology's Avatar
    CT
    Lest we forget one of the most badass F1 engines of all time...
    BMW M12 - Wikipedia, the free encyclopedia
    BMW Turbo F1 Engine
    1986:
    Qualifications: maximum of 5,5 bar with Benetton cars: about 1300 bhp.
    Boost Is Better
