Results 1 to 10 of 10
Thread: Transmission Question.....again
05-27-2011, 02:35 AM #1
I know that you guys may have seen this post in other sections but from each car I have gotten different answers due to the cars in question having differents setups. So here we go again, I'm reaching out to the community here, what is the noise I'm hearing in between upshifts? Anyone?
http://www.youtube.com/statjr (Please Subscribe)
Follow me on twitter @babystat
Find me on Facebook Elijah Superleggera Sumrall
Hi-Res Car Pics Razzi.me/Babystat
For you business Pro's: http://www.linkedin.com/pub/elijah-sumrall/37/926/2ab
05-27-2011, 02:46 AM #2
In vid 1, rev matching maybe? When you let off the throttle some cars have a crackle... it's prob just that.
Hazing GDI's since 2011
05-27-2011, 03:19 AM #3
05-27-2011, 03:21 AM #4
05-27-2011, 03:40 AM #5
The ecu will pull fuel, retard timing and/or chop the throttle momentarily to help sync the shift and the brief torque limiting can sound weird if the exhaust has been altered. The oem exhaust usually is tuned acoustically to mask this event.
As long as it's not making a scraping sound like gears striping between shifts, you should be fine. If the transmission itself is the source of the noise, a synchronizer is likely damaged.
05-27-2011, 06:36 AM #6
05-27-2011, 11:41 AM #7
05-27-2011, 04:25 PM #8
05-27-2011, 08:15 PM #9
When you go fron wide open throttle to closed (mid-shift for example) the car engine will spike rich as the intake air slows momentarily and the fuel injection takes a split second to catch up with the change in intake volume. This rich exhaust mixture is then burned by the catalysts and you get your exhaust backfire.
Thomas Wu
O'Gara Coach Company
8833 W. Olympic Blvd.
Beverly Hills, CA 90211
twu@ogaracoach.com
310-659-4050
Current Inventory
Authorized Dealer For:
05-27-2011, 08:18 PM #10
Thomas Wu
twu@ogaracoach.com
310-659-4050
Current Inventory
